PS Seat Fixed! I made some observations. Sorry, no pics...
First, read this thread generally from page 1.
These are my notes, basically because I found an issue I didn't see in previous threads on this...
General note on production of these.
These gears have 3 ejector pins... so... not 3d printed. Unless someone has their own arburg set up in the garage spitting these out unattended with a multicavity mold, hopper/feeder/conveyor - the price is inline with low volume setups and production runs. I've charged a lot more for a lot less nylon - Not my fault the Gov't only wanted us to run 5 of something they spec we can't stock - Machine/material/mold Setup, qa testing/FAI, and eventual mold repairs/maintenance take time and money. Unless you're ordering 1.5M of parts, then we can talk about 1.5 cents per pricing
These gears are a good part IMHO.
Note 1. Upon removing my gear carrier - I have the thrust bearing assy but no thick washer - Is it possible that what people think is a thick washer is actually dried out congealed grease? I had a 1/2 round brown orangey thing that that looked like a washer, but was definitely grease... (See Note 8 about tightening). My outside housing/retainer had to be pried off, and 'grey' washer was not not removing easily from the shaft. Upon close inspection I noticed a hairline fracture - thus upsetting the diameter just enough to keep the washer from slipping off and keeping it bound in the housing.
Fix: I chucked it up in the drill press and ran some emery cloth and 2000 grit wetdry on it until eveything slid together without any binding/catching. I checked the other side, chucked it up and polished all the ends of the gear carriers end for end, side for side.
Note 2. Clean out all of the old grease from all the plastic housing parts. The flex shaft, SS worm gear, the drive screws. Depending on your appetite for bravery... take the motor apart and clean the commutator and that worm gear and housing.
When putting the motor back together, put the housing in a vise (the part with the brushes pointing up) - unhook the brush tension spring and poke the brushes apart. Seat the motor in the housing, relatch the brush.
Then, carefully put it back together by:
Take the motor housing, pass the flex shaft through it (basically using the flex shaft as a guide through the magnets) - keep a finger on the end of the flex shaft and put the flex shaft into the end of the motor shaft - like:
===MotorShaft====|---flexshaft---|||||motor housing/magnets||||----flexshaft.
Keeping finger pressure on everything, push the motor housing down to where it belongs and screw it back to the gear housing.
I used some valvoline ford bearing grease, but I suspect anything decent will be fine.
Note 3. Pressing the gear on - a 12mm socket just fits the carrier shaft and stops at the shoulder of the retaining teeth. But, there is really no positive alignment/engagement of the retaining teeth to the ID of the gear.
Fix: Chuck the carrier up in the drill press and carefully hit the outside of the retaining teeth at an angle to create a slight bevel/chamfer. This should allow some easier alignment to the ID of the gear.
Note 4. Pressing on after creating the chamfer - Vise Jaw | Socket <-> Gear<->Carrier | Vise Jaw . Snugged up on the vise, used a little heat, pressed until the socket stopped at the carrier teeth. This is a positive/hard stop.
Note 5. Flex shaft driven/remote gear reassembly notes:
Put the little white end cap in, this carries the end of the flex shaft driven/remote worm gear. It does not need to be clamped down tight as to prevent free movement of the worm gear. You should be able to take the flex shaft and spin it and watch the gear carrier move easily. If it doesn't move freely... then there is a problem - make sure your gear carrier turns freely in the housing, make sure your carrier ends aren't gouged or otherwise impeding free movement. Try loosening the end cap.
Note 6. Repeat same basic reassembly steps for motor driven gear assembly.
Put the whole drive assembly gearboxes together and re-install as a complete unit.
Note 7. Read others advice on keeping the threaded shaft at the same length on each rail.
Note 8. There should be no slop between the retaining nut, the end of the gear carrier/housing and the shaft - you should not see any of the teeth of the drive screws that engage through the gear carrier/housing. But, do not overtighten these - there is a thrust bearing in there that will take the load, but should not be clamped tight. I think this is why I do not have a 'thick' washer in the gear housings - there's no where for the gear to go if everything is assembled correctly. If there is a washer between the retaining nut and the gear housing, make sure that it is smooth side against the housing with no burrs to catch the housing.
Note 9: Once you've snugged everything up, throw the seat back in the truck. Before bolting everything back down, tilt the seat back and run the seat fwd and back. Double check the travel of the slides, admire your work, then bolt it back down to the floor.
Good Luck, and thanks for a great product.
