rusty_tlc
Dain Bramaged Member
I've heard of this a couple of times. Why does anybody think air lines are more reliable than wire? I work around industrial automated assembly machinery that runs 10+ hours a day, lots or wire and air lines. I can tell you from many years of experience that wire is much more reliable than air or vacuum line. I have never had an ARB solenoid fail, ever, in over 10 years of service. If you are totally paranoid they are cheap enough that you could carry two spares.If worried about reliabilities of air and electricity with ARB lockers, people could do what I've done.. I installed an ARB heavy duty air line and tied it to the brake line.. How often do we tear our brake lines out? I have eliminated the ARB air solenoid by installing a pneumatic toggle valve into the dash.. I use an ARB CKSA12 compressor permanently wired to the ignition, eliminating thier wiring harness.. Whenever the vehicle is running, my front locker is ready for use..
Obviously this setup still needs periodic inspection and maintenance, but removes a lot of potential for failure..
I would re-wire your compressor, why run it 100% of the time if you only use it 10%? Adding extra hours of run time is not going to help the reliability. On my UZJ100 front locker I wired the solenoid and compressor in parallel, the solenoid takes such a low volume of air that the lag caused by the compressor pressurizing the system is not noticeable. Since the CKSA12 has no pressure tank this works well. The RDCKA has a tank so it takes a while to fill. If I had the money I would replace the RDCKA in my FJ40 with the CKSA12 and wire it the same as the UZJ100.
