Front Differential Bushing Replacement - the Easy way! (2 Viewers)
Mine is completely gone (so far) but I am not sure exactly what to attribute it to since I replaced so many components in the front suspension. But for now....I have no clunk at all.
We will see how long that lasts. I think a good amount of mine was CV Axle to Drive Flange fitment.
Of more importance to me....is the improvement in steering after replacing the steering rack and all front end bushings. Going around corners a highway speed now just takes a bit of 'pressure' on the steering wheel where before it more like steering a boat. Worth the effort for sure.
Thanks Flint! I'm going to knock out the rack this weekend!
Got it to here... now how do I get it down and out???
If you can get a bimetal sawzall blade in there and cut a notch in the bushing that will relieve pressure.
  • Like
Reactions: MDK
I wonder if I am the only one who went through all the same trouble to replace these bushings to find out they weren't causing the clunk and not really that worn out in the first place.
Do I have to pinch out 360 degree of the bushing before I start pushing it out? Trying to get the back of the bushing out is nuts. Can’t even swing a hammer back there
I talk about that in both my diff bushing videos, I think. You have to hit it down and out. You do *not* need to break the lip free all around. once it starts moving, you can move around the exposed areas and creep it down.
It takes about 30 seconds with an air chisel. A whooooooole lot longer with a traditional hammer, haha.
The difference was minimal on my 06. On my 99 it was more significant, but still not the sole cause of clunks. The 100 is annoyingly clunk prone when it comes to R-D shifting.
Yup. Tried with a hammer.
I look like this now.
Will be attacking it with hammer drill (chisel bit) tomorrow morning to finish the job
Basically it is wedged in there so you gotta work it back and forth, side to side. Once she starts coming out you will hit a point where it will be moving along like it has and then suddenly just "fall" out. Clean up the hole with a file so that you don't have any marring spots and you are good to install the new one. I did like @2001LC did and put a schmear of Red Mobil 1 grease around it to help slide it in.
Also note THERE IS ORIENTATION DOTS!!! PAY ATTENTION!!
RIGHT!!... You did all the hard work by hand and then the easy part with the hammer drill! I know I sat there and worked mine from the beginning with the hammer drill and was freaking out because I was like 10 minutes in and it had barely moved. Remember what the guys said about the "point of no return" so took a quick break then went back at it. After that it was literally hitting it from both sides for a few seconds and the thing just about fell out. Literally stopped the clock and almost called the game at 11:59 when I was just looking for 12:00.
Hahaha as soon as I looked at it last night all torn up I thought - “well i have to replace it now for sure.” :meh:
FYI for anybody doing this task, unless you possess Herculean strength and endurance please get a hammer drill or air chisel.
Right... I hit that point too and was like "Welp...s***...... Ok its gonna have to come out somehow."
And yes, the air compressor with the hammer drill is the 1-2 punch. I purchased the $12 HF special with a set of extra chisels (not realizing it came with one) and that did the trick for me. Don't know if I will ever use it again, but it served its purpose, went into the tool bin and will be there until I need it again.
IF you are equipped to do so, then 'boring' the center section out first will allow for MUCH easier deformation of the metal shell and removal of the old bushing.
An 1-5/8" hole saw in a 1/2" drill makes short work of it.
The alignment marks on bushing translate to - dots to the front - right?
Correct. Single dot to front.
To my knowledge it has not been revealed 'why' the bushing is oriented such, only that it is (from the factory).
This is correct.
Also know that as you press the new bushing it, it will probably get about halfway in and then start to get a bit kaddywhampus... Don't bother completely removing the clamp, just loosen and orient towards the side that is "more" out than the other. Start the process again, going slow, and this should realign everything. I believe that as you start going the clamp tends to shift on the bushing which causes the misaligned install happening. So just take your time, adjust clamp as necessary and same thing will happen, once it is about halfway in, it will suddenly just start moving quickly.
This is correct.
Wow. Bushing isn’t pressing in at all.
