I have 1.25 inches at the front, and 2.25 inches at the back. I had to notch the frame to get the tie rod in on the driver's sideCould you help with a measurement on your leaf spring sliders? See picture for details. I'm hoping to see if I would have enough clearance between my frame and my tie rod with this modification since it will lower the ride height.
View attachment 2512706View attachment 2512707View attachment 2512709
A few more pics, can't believe how great it drives. Definitely needs a re gear, 75 in 3rd gear with more rpm to go.
View attachment 2521384View attachment 2521385View attachment 2521386
Yeah I'm thinking I may go that way first. Are those gears helical cut. I really like how quite the split case h42 combo is. There is zero noise. I may do the 3:1 gears and 4.88's in the axles. Either way it drives ok as far as current gearing and the ls power. Hitting 70mph in 3rd gear is pretty funYou could do 4:1 gears in the split case. Then have a 10% reduction in high range.
