Build Frog's 40
Battery is in, powered up the gages. Almost all electrical is done, just have to wire up the fuel pump.
Pretty cool all the options available
Figured out the smoke, the map sensor was programmed incorrectly by me. I set it to internal initially. The terminator x computer has an internal map sensor built into it, and the little hand held does not give the option to program a stock sensor. This error was making the engine run rich at 12.7 afr. After hooking up the laptop I was able to reprogram the computer to use the stock LS map sensor and it runs much better (14.0 afr at idle). No smoke now
