Builds Fj73 Crawler build, (1 Viewer)
Front axle rebuild, u bolt delete, boxed wedges and plate lower ball gussets,
Tonka,
Those PBRs are sexy as fxxx. That's the tire I want!!!! My 42" TSLs are good, but PBRs are bad ass :D
Piano theme continues, lol,
IFS hubs,
Redrilled fj73 SA disc to bolt up to IFS hubs,
Offset comparison,
Fitech 400hp Fuel injection carb,
Spacer plate for dual plane manifold,
Beginnings of surge tank and hi-pressure feed,
Repositioned the winch solenoid and controls inside the cab,
Nifty bulkhead fittings,
Winch isolation,
Main feed isolation,
Mounted the winch controls centre,but also removable easily for hand held operation,
Fuel system builds,
Sitting pretty, ish, need to tune the front pack to lower it a bit,
With the introduction of fuel injection it became apparent that the underdrive gilmer drive pulleys weren't charging enough to run the system at idle, so back to standard crank and water pump pulleys and v belts all round,
Short (old) vs long (new) waterpump
Sky Chromoly straight and short pitman arm, very nice bit of kit,
Now we're talking .. nice fab work. You need to fix the front caliper lines though.
Built up a little ebnder to make some fold back mirrors,
Added some walls to the die to help with flattening,
6 inch mirror mounted
Tuned the front a bit more with the removal of another leaf, just about spot on now,
