Build Fj73 Crawler build,
Front axle rebuild, u bolt delete, boxed wedges and plate lower ball gussets,
Tonka,
Those PBRs are sexy as fxxx. That's the tire I want!!!! My 42" TSLs are good, but PBRs are bad ass :D
Fitech 400hp Fuel injection carb,
Spacer plate for dual plane manifold,
Beginnings of surge tank and hi-pressure feed,
Repositioned the winch solenoid and controls inside the cab,
Nifty bulkhead fittings,
Winch isolation,
Main feed isolation,
Sitting pretty, ish, need to tune the front pack to lower it a bit,
With the introduction of fuel injection it became apparent that the underdrive gilmer drive pulleys weren't charging enough to run the system at idle, so back to standard crank and water pump pulleys and v belts all round,
Short (old) vs long (new) waterpump
Sky Chromoly straight and short pitman arm, very nice bit of kit,
Now we're talking .. nice fab work. You need to fix the front caliper lines though.
Built up a little ebnder to make some fold back mirrors,
Added some walls to the die to help with flattening,
