Builds Fj73 Crawler build,
Rebuilt the spare wheel carrier, Sunk it some and set it rear ward a bit, with room for 42's,
Y strap,
Have a question on that hand brake. Does it lock on, like an ebrake, or is that for drifting only?
It does lock. See the slotted area there's a drop down pole that wedges on the slots. Pretty cute design actually. They do say thou that hydro brakes aren' ment to be used as a stand alone park brake as if there's pressure loss the brake let's go. But for stop start use it' perfect
What model is that unit? I am needing that exact thing!
Chop chop,
more sheet metal gone,
Hard lines in the making,
Stuff buying hose clamps, built up some,
Next up Bump stops, 2x4 Profender hydro bumps,
There mounting cans and very nicely done, stout materials,
Full compression, ended up moving it up 25mm higher to get a little more tuck,
New hardlines front to rear with hydro handbrake plumbed new front softs and no leaks,
Really like those brake line clamps you made. Crafty..... And still want your ebrake setup!!!
Snorkel and airbox out,
Headlights sung,radiator hung,guards hung, winch mount front bar work started,
The gropper,
Hydro steering fluid reservoir mounted,
Pitbull Rockers 42x15x16,
Front end approach with new barwork,
Fits like a glove,
bit of trimming required out back,
Dat Ass,
Turned out some bonnet pins,
Guide plates,
rear end tune, lost two more leafs out of the rear pack, they where way to stiff with all the weight gone from the rear end,
Rear stuff, had a bit more in the tank but have some front end clearancing to sort,
Them bastards are BIG,
Top boxed ball gussets
