I'm just starting this conversation and would like some advice on the steering box placement, mounting options, what I should or shouldn'tdo, etc. Also pics of your set up would be helpful. Thanks
I have some comments of that nature in my build thread in my sig line...
The box lined up naturally where the hole in the front of the pitman arm was in line with the large hole in the frame. It actually could go forward just a touch further so as to not have to trim quite so much of the fender as I had to. I have pictures in my thread.
If I were to do it again, I would keep the FJ40 steering column but cut off the rag joint end and grind it to mate up to a Borgeson intermediate shaft with a slip joint. I would also get a custom drag link/relay rod made rather than use 70 series parts. Those are both in the interest of saving time and money, and having a more ergonomic and clean installation in the end.
Nope, I used a plate to space the steering box off the frame and keep it away from the radiator support, so I have about a 1/16" gap between the box and the radiator support. The support rod I still haven't figured out - will probably end up running something back to the firewall or something. Not sure.
How long have you been going without it?
I haven't figured mine out either -
Since I finished it in '09 - hasn't been as many trail runs as I would have liked tho
Ford shock towers, 1/2-3/4 inch spaced off frame rail, AFCO 3/4 smooth bore joint on stock 40 column to stock 60 input shaft to box. Port the box for hydro if you are going to get it rebuilt.
