I’ve hear that I can change my carburetor to a fuel inspection system, is that true?
For which option? For the V8 swap that is about right depending on the work being done, starting point is usually about $10-$15k then goes up from there.I would love this but got a 20 to 30k quote, yikes. So I'm also looking at efi for my 60
Right... Nolan @wngrog has had great success with his. Think the two hardest things is 1) finding the right adapter between the 2F intake and the TBI/AFI/Etc. unit and 2) finding the adapter for the EFI head to the stock air cleaner.Holley Sniper, or a kit from Affordable Fuel Injection would probably be most cost effective. The AFI kit has been a good success I believe
yes the V8 swapFor which option? For the V8 swap that is about right depending on the work being done, starting point is usually about $10-$15k then goes up from there.
Wouldn't the "simplest" option be to drop a good 3FE into the truck? Mostly plug n play aside from mounting the EFI ECU?
I love my AFI.
That said I’m also liking the Holley Sniper kits @FJ60Cam and @Dustin Messina just installed.
