FJ60 Door Refresh
Discussion in '60-Series Wagons' started by John Staton, Nov 22, 2017.
  1. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
  2. John Staton
    John Staton
    310
    Media:
    1
    181
    Oct 23, 2017
    The Woodlands, TX
    I have a couple of questions and maybe someone following this thread can answer
    1. when my passenger side window is down and you shout the door it clunks a few times like some assembly is loose. Does not do it on my other doors. Wondering what this could be as I want to preorder the part before I teardown.
    2. I have seen replacement weatherstripping for doors...the one that is on the inside of the window I think is attached to a chrome strip. Do they sell the replacement piece that also has the chrome strip or is that two different pieces?
  3. gregnash
    gregnash Anal Retentive Analyst SILVER Star
    9,007
    2,485
    Nov 4, 2011
    Carson City, NV
    Chrome piece is NLA, most have been upgrading to the 70s rubber wiper as it fits just about perfectly.
    As for the door clunking around, you need to pull the panel and take a look. When the window is down it is still in the window channels, or at least should be. Maybe a channel has come loose and is rattling becuase the window is down or it could be that the window is not aligned properly and thus coming out of the run.
  4. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    I just replaced my front outer door felt. the 4 pack I got from Racer City here: Outer Window Felt / Seal for Land Cruiser FJ60 - Set of 4 includes the clips and the rubber piece that has the felt. I pulled my old ones off knocking the white clips loose, breaking most of them and letting some of it fall down into the door. Once removed I took the new white clips off the new rubber. Then I clipped the rubber to the original chrome using the new clips. Finally I lined up the clips with the holes that receive them inside the door. I made sure the rubber was centered so I didn't have a gap at the front or rear of the window. Then tilting the piece I angled the pointed ends of the clips into the holes. Using my fist I beat the piece into place. Listen for them to "click in". This last part made the chrome flush up...esp at the front where it likes to pull away from the door. Haven't tackled the rear doors yet. I have to study how the fixed window rubber is pinned in place and how I can get the chrome out from it w/out disturbing the rubber.
    I noticed the new rubber angles in much more than the worn...and is tighter against the glass. I also noticed the old worn rubber had and internal metal support that was pretty much rusted away. You can do this w/out taking the window out or the door card off. At least for the front doors.
  5. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    DSCN0026.JPG DSCN0025.JPG DSCN0024.JPG Here are the new outer felt pieces installed (front only)
  6. tmxmotorsports
    tmxmotorsports
    393
    150
    Jul 3, 2016
    OBX Nc
    So those can be ised with the chrome trim?
  7. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    I broke the old white clips loose using a flathead screwdriver. They are located just inside the door and below the felt. twist them with the flathead or push them down. Either way they will probably break. Mine were a little different than the new ones. Here are pics of the old clips and the new.
  8. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    Yes.
  9. tmxmotorsports
    tmxmotorsports
    393
    150
    Jul 3, 2016
    OBX Nc
    Cool good to know
  10. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    I installed the fuzzies in my rear side doors today. The driver's side went in very easy. I went to pop the old rubber out with a flathead and amazingly all 4 clips stayed in place. Piece of cake just pushed the new rubber down into the clips and gave them a good bump with the fist.
    Went to the passengers side and didn't have as much luck 2 clips fell out. After several attempts to just put the clips on the rubber and try to snap in the door I realized I would have to do like the front doors and take the chrome out. You have to sandwich the chrome and the rubber together with the clips. Although I was able to work the chrome out of the fixed window at the back of the door, I was unable to get it back in place. So I ended up taking the door apart and removing the fixed window to set the chrome and rubber in place.
    The rear doors (at least mine) have no slots for the pointy barb on the new clips that come with the felts. So the new clips don't work. No problem the back clips stayed in one piece and I had left overs from the front doors. I reused the old clips. Bumped the piece with my fist til it clicked in. And visually inspected to see that they were grabbing inside the door. Then put the door back together. If you want to take the back door apart it's not too hard but there are some diff from the front doors. The regulator comes loose with removing the 3 10mm bolts from around the crank, then it just slides (edit) the roller out the track at the bottom of the window. No unscrewing or removing the window. You can leave the window in the door. Next remove the window run. take the two 10mm screws out of the door near the back and here's the tricky part...there is a screw at the top of the door under the door weatherstrip. Once you get that you can pull the run channel out. Next slide the fixed window forward, some spray lube helps move things here. Once it's about 8 to 10 inches forward in the window sill you can tilt inward and remove. The rubber can stay attached to the window. After putting the chrome and new rubber back in the order is in reverse but the fixed window will be harder to get back in place because the chrome is there. When the fixed window is in place, put the channel run back but make sure the window is in the track as you lower into the door. The rest is pretty easy.
    maxbob002 likes this.
  11. g-man
    g-man SILVER Star
    1,367
    996
    Sep 5, 2006
    Charlottesville VA
    I just found out cruiserparts.net sells the escutcheons for the window cranks. YES that is a word. the clear washer looking piece that goes behind the window crank. Mine were looking pretty shot from all the taking on and off.
    joebattle1 and maxbob002 like this.
  12. joebattle1
    joebattle1
    267
    186
    Jan 11, 2009
    Oakland CA
    I’ve been hunting for these things lately. Thank you.
    g-man likes this.
  13. 4Cruisers
    4Cruisers SILVER Star
    3,218
    3,112
    Apr 2, 2015
    69266-22010-08
  14. joebattle1
    joebattle1
    267
    186
    Jan 11, 2009
    Oakland CA
    Ordered. Thank you!
