1973Guppie
Supporting Vendor
So I got the tow bar attached to the front 40 bumper this weekend and hooked it all up to the new Tundra. Drove it around the neighborhood (35 tops) and it pulls and tracks great. I realize I need to test it at a higher speed, etc. but so far it looks good. I did however have a few questions on how I might improve the towing situation and wanted opinions on if these things would help minimize sway, etc when flat towing.
The rear of my 40 is heavy. I have a spare conferr 2nd tank, spare tire, co2 tank, gas can, BIG tool box, etc. I am thinking that when I tow I could pull the spare, co2, gas can and empty the tool box and store this stuff in the bed of the tundra. I am thinking this will help greatly with the sway at the rear of the truck as it puts all that weight in the tow vehicle and not all the way back there at the end of the truck. All of this combined is alot of weight. I also plan to pull the 2nd tank (aussie type) which should help some too. I have read before that you want to have as much weight as possible toward the tongue of the towing vehicle. Will this stuff above help the towability of the 40?
Also, I have 55 springs and was planning on pulling the rear 40 springs and installing the 55 springs in the rear. I am thinking that doing this would bring the axle farther back and maybe make the vehicle a bit more stable when flat towing? Will this help the 40 be more stable when towing?
Also, I plan to pull the rear driveshaft when I flat tow. Anyone know of any innovative easy devices that allow for a quick release of the driveshaft? I have heard of devices they use on vehicles that sit behind RV's but not sure if they would hold up to 4x4 abuse.
How fast do people drive with their vehicles being flat towed? bar says 45 mph but I am thinking 60 should be ok, especially on a flat straight away.
appreciate comments / tips from those more experienced on this matter than me.
will post up pics of the whole setup later...
Thanks!
Noah
Thanks!
Noah
