Any suggestions to pop the brake drums off? Its a 72 and we tapped on them with no luck. Thanks in advance!
Did you remove the set screw (near the wheel studs). Assuming it is still there after all these years.
Get a brake puller from a parts shop. Mike
try wedging a flat head screw driver in the hole on the drum and get it to wedge things a bit. Start wiggling from top and sides, should start to get loose after a while of that and a BFH.
