FJ40 Brake Drum Removal
Hey Everyone,
I recently picked up a '73 FJ40 and am trying to remove the front break drum. The wheel doesn't spin and I'm thinking the brakes are locked/frozen against the drum (FJ40 hasn't run/moved in 20 years). In looking at the drum, I do not see a set screw. I see two holes in the drum, one slightly larger than the other, but there is a piece of steel behind it (no threads), so I'm thinking if I could spin the drum I would be able to see the female threads where the set screw would go in.
My question. Is the set screw obvious on the front of the drum and does it sit in one of the two holes? If so, then I suspect it was removed years back and was never reinstalled. If so, I'll follow the advice in this thread and start with the hammer and move to the torch. I'll also pull another wheel that spins and see if I see the set screw. I did try backing off the breaks via the adjustment hole on the back of the wheel, but it doesn't feel like it is giving.
Thoughts or advice,
thanks,
Brian
'73 FJ40
Hey Everyone,
Thoughts or advice,
thanks,
Brian
'73 FJ40
