I thought stoic AFR was 14.7:1?
Hmm... Feeling less intelligent with every subsequent post.
My mistake on the temp. I thought you were saying EGT went up with rich. CHT or coolant temp does increase when the engine is loaded and running at max power AF. Running lean does not increase the heat of the combustion process. Running lean will incinerate valves & pistons because there is superheated free oxygen in the endgas, just looking for something to go bessemer on.
spectre6000 said:Carburetors work via pressure differential. Air moving over an orifice (the inside of which is atmospheric pressure) creates a negative pressure zone. That negative pressure draws air/fluid toward the stream (think of those old-timey perfume bottles with the squeeze bulb). In a carburetor, this is taken advantage of via the bowl. Fuel in the bowl is at atmospheric pressure, and there are various channels with apertures leading to the carb throat through which air is flowing at speed by means of the vacuum created by the retracting pistons in their cylinders. Venturis and throttle plates are used in the carb throat to control, manipulate, and optimize the air speed (and thus the pressure differentials) in the carburetor over these various apertures at various engine speeds. Meanwhile, the airflow to a given cylinder effectively has a very limited and finite time to be properly charged with fuel. That time is dictated by the cam and defined by the amount of time the intake valve is open. During that time, the carburetor controls how much air is allowed in (it's always a bit restrictive in order to have sufficient rate of air flow to create enough vacuum to draw fuel from the bowl), and the number, arrangement, size, etc. of the holes in the carb throat dictate pressure differentials at that occur between the bowl and the throat. The jets come into play by metering the amount of fuel allowed to flow (like an hour glass) at various pressures from the atmospheric pressure of the bowl to the low pressure zone of the throat during the intake stroke.
There is a lot more involved, but that's about the minimum to explain the role of jets.
To answer the minor displacement question in perfect vacuum/perfect sphere terms, yes it will affect your jetting because of the difference in flow rate of air and gasoline and the delta in flow rate created by the increase in displacement. This can be ascertained by comparing the average viscosity of air at your altitude and temperature compared to the average viscosity of your chosen variety of fuel at the same, then calculating the difference in the flow rate of the previously displaced volume of air compared to the newly displaced volume of air over the same period of time, then (reading back through, I can barely follow this and I doubt anyone really cares... time to truncate) do some calculator magic and increase the size of your jets according to the result. There are very thick books available on the subject with lots of complex formulae. This will likely result in small differences, and necessitate a set of VERY fine jet reamers.
Alternatively (and an infinitely more common approach), start with the factory recommended baseline, then get a bunch of jets in a range of sizes and swap them out until all RPM ranges react how you want them to with minimal adverse effects.
Or in more practical terms, assuming the general difficulty of obtaining jets for these specific carburetors and the general insensitivity of the engine, no.
Where is "Pigsty, CO" that we are neighbors? I'm fairly new to the area, but I'm pretty sure that's not a place... I'd like to meet some mudders if there are any nearby.
