- Joined
- Oct 25, 2008
- Threads
- 40
- Messages
- 1,331
- Location
- Central Oregon
- Website
- www.oregoncruisers.com
A new thermostat and housing so you can
Ok so I can tinker with her a little bit.... When the 40 starts it will run for a few seconds and then die. If I hold the choke about 70-80% closed I can get the 40 to run for a minute or so but it still dies short after. What should I look for now????
Thanks,
Drew
First thing I check on a carb from some unkown place is float level. Used ebay, probably lucky if the float floats.
But do not ignore your points and timing either.
For tuning purposes on that carb, start with the idle needle 4 turns out from bottomed.I went ahead and backed the idle mixture screw down to 1.5 turns from fully closed and that had no effect on the idle situation. I then removed the idle solenoid needle and fired it up and she ran and didn't die. So I believe that problem is fixed which is great aside from the new problem that arose at soon as the previous one was fixed.
I got her running which is great but as soon as I touch the throttle and try to give it a little gas it immediately stutters and dies on me.
So once again what should I look for now?
Thanks,
Drew
