I don't have my receipts here at work. I spent so much money on my 40 I have pproblems remembering how much I spent where.I know it wasen't cheap, nothing was.
...Better off NOT knowing, really. That's why we call them 'hobbies'...
Another vote for popping your pinyon angle down a couple of degrees. I'm new to cruisers, but have done four spring over's in my day and nothing can surprise me anymore.
If you're just setting up those springs and have that pinyon pointing straight at the Tcase like that, you will regret it later. As Cruiseroutfit said above, ALL springs will sag and settle over time, specially in the first 500 miles (or 2-3 trail rides). You will find yourself with a "negative pinyon angle" (meaning pointing OVER the driveshaft, or beyond the angle of the top joint on the Tcase) and this is a very bad thing. The joint wont last long.
The U joints on a shaft must work together. And keeping them at the same relative operating angle is the best way to optimise their strength and life. This is most important on the rear shaft, as it does most the work and all the high speed work (keeping them the same angle also avoids vibration).
Also, for what it's worth, I dont care for CV shafts. I know others above are pushing you that direction. And, if this is going to be your DD and see mostly road work, that's fine. Less vibration, specially if you plan to keep that pinyon angle. They make up for differing angles on the axle and case. And if you have to have a CV, talk to Jesse at High Angle like you are. He makes the best. Otherwise, using OEM CV's in my very long road of playing with this stuff only served to frustrate the hell out of me. They came loose, broke or otherwise pissed me off to no end. I prefer a good single 1350 or even better, CTM joint on each end of the shaft... and use high angle pinyons when possible. I've found them to be much more durable, specially for rock crawln.
Cheers!
Oh, I'll be starting my 60 SOA soon. Thanks for the pics and good post.
Great work Keith!!! Looks like it was a good call to stay home Saturday and work on your rig instead of catching a ride with one of the gang.
We had a great time sorry you couldn't make it. You missed the biggest turn out of Dan's yet, five countem five altogether.![]()
I played with my spring packs for two weekends before I was satisfied. In the first couple of weeks just sitting everything settled a bit. Now after a few trips which flexed things out the rig has settled a bit more. I'll probably add a leaf back in the front packs. They are pretty flat.
I guess your committed now!![]()
Right on man. You know what you want and are going for it. I applaud that. I've found over the many years of building this stuff, sometimes you have to just take what you got, tune out the white noise, choose a direction and go with your gut. Nice job. Ask 10 guys, get 10 different answers. Thats what's great about this pastime, there's no one way to build these things.
I'm not intimidated in the least with the SOA, but I'm VERY interested in your knuckle turning the cruiser axle. Keep the pics and posts coming. It's getting very interesting now and you're doing a great job.
So will you bolt up the houseing and on jack stands, put the springs under load in order to get the right castor on the knuckles before setting?
Cheers!
