- Joined
- Apr 18, 2007
- Threads
- 4
- Messages
- 29
I have a 00 LX470. Where can i find the abs module? Thanks.
I would add to your original post: to get the old resonator off you need to heat up 2 of the pins at the same time so you can lift and bend the resonator up slightly and finally apply heat to the last pin to remove.
Thank you x200! Pulling the old one was my biggest hurdle in this process as well, I put a wider tip on my hakko to reach and repaired not only mine but the used bad one that my mechanic bought off bay to replace it. I can’t thank you enough for this write up! I don’t have a ‘scope but when the resistance went through the roof on my multimeter, I knew I had a good chance this was the issue, but never would’ve known where to start without this.Awesome, glad to hear it all worked out!
Yeah, I've found that a hot air gun/rework tool is best for surface mount devices like this.
That is great to hear! Keeping LCs on the road is the main goal.Thank you x200! Pulling the old one was my biggest hurdle in this process as well, I put a wider tip on my hakko to reach and repaired not only mine but the used bad one that my mechanic bought off bay to replace it. I can’t thank you enough for this write up! I don’t have a ‘scope but when the resistance went through the roof on my multimeter, I knew I had a good chance this was the issue, but never would’ve known where to start without this.
It's usually the case, the know-how/labor out costs the failed component.Nice to know there’s an easy fix for things that can cost $200-800+!
It's possible. Two key things for me were:Does this light show look like a bad control module repaired with new “ceramic resonator” ??
Quickest test will be the Ts E1 jumper on the diagnostic block under the hood and see if you get codes vías the blinking dash light. If no codes, then it's likely this issue. If you get codes, even the "all good" code, then it's not this issue.@FJRyder, I am looking to buy this 2000 LX with these dash lights on. The owner's mechanic says he can't pull any codes from it with his particular code reader (maybe due to no computer communication). So I am assessing the situation to determine the cost to repair. I drove it and it drives and brakes fine.
The car will drive fine with this issue. The main concern is that there is no ABS or traction control functionality.@FJRyder, I am looking to buy this 2000 LX with these dash lights on. The owner's mechanic says he can't pull any codes from it with his particular code reader (maybe due to no computer communication). So I am assessing the situation to determine the cost to repair. I drove it and it drives and brakes fine.
