- Joined
- Jun 21, 2011
- Threads
- 234
- Messages
- 21,833
- Location
- Redding, California
- Website
- trail-tailor.com
AH!! PROGRESS... I like new tires...
J
J
Greg, you gonna do just the TREs or the rods too?So once the new tires are on I will be taking the truck to my buddies house who has a barn and pnuematic tools and we will be taking care of the TREs finally and then doing an alignment.
I touched up my frame and started off using a wire wheel on a grinder. I then switched over to a sandblasted.
There is no comparison between the two. A wire wheel just does not do it in my opinion. It takes a long time and only knocks off scale and flaky paint. The sandblasted truly eliminates the rust.
I live in canada where rust is a very formidable opponent. Even reevesci would have to take a breather from fighting canadian rust.
The only way to combat it is by eliminating it with no mercy, wire wheeling will just slow Iit down a bit.
my little bobbin/cotterpin that holds the arm to the actuator on the carb. Quick little garden wire fix and it works fine now but is the pin still available?
Ok quick question.....
This morning while turning the corner to my office the throttle response went dead, and I mean DEAD. Truck still idled but pushing the accelerator did nothing. I instantly knew it was the throttle cable, pulled over and looks like I lost my little bobbin/cotterpin that holds the arm to the actuator on the carb. Quick little garden wire fix and it works fine now but is the pin still available? (@beno @Sam Stewart)
