$24,864.22
Uh...locally the estimate is $15-17K to get this done as a one-off. If I was a super successful salesman instead of a oneabee...then maybe
$24,864.22
Uh...locally the estimate is $15-17K to get this done as a one-off. If I was a super successful salesman instead of a oneabee...then maybe. Speaking of which (the former...not the latter): John this should be right up your alley...
)Hey Jay the 100 looks good!
(from the kid that looks like you 30 years ago)
Dylan
Rusty_tlcIs that the same guy that drove your rig through Deer valley Last weekend?![]()
Yeah, but don't you need it for on road travel?
So did you chuck yours in the garbage? What use does it serve by being on the truck then?
It benefits road handling. And apparently not to the detriment of articulation. If I had time I'd try it without the sway bar in the rear...but I suspect it actually does add some control/anti-lean capabilities for on-road handling. If not then I'd gladly yank it and save the weight...
Someone on this board has probably tried it on the road without the rear sway bar...hopefully we'll get a chime in.
Yeah, I tried to make a quick release like I did with my 4Runner but on UZJ100 once both side of sway bar is disconnected, the ends of sawp bar will dropped almost one foot pointing downward. I'm not sure how to keep it hanging yet disconnected?
The sway bar stopped at 8" becuase of interfence with the parking brake cable on the other side of axle.
Instead of building brackets to drop down to the sway bar ends, why not just lengthen the sway bar? Cut the ends off, extend out equally on both sides, and weld the ends back on???
Anyone tried that?
Anyone tried that?
Yes: I extended my sway bar brackets (actually the connector rod not the bracket itself) by 50mm when I did my 4.88/35" conversion. Next will be an adjustable pan hard and adjustable upper control arms.
What differences have you noticed with the longer sway bar link? Did you use thicker material?
