alrighty, here is what you need if you're just going to get parts from later years, to include the same style fan that you're using. Mine is a 1971 as well with this "upgrade" of parts tossed in (minus the 2F engine)
A 1975+ fj40 fan shroud. Yes, it will not fit in its original configuration with the larger fj60 fan. Really, all i did was get some tin snips and cut the outer edge off of the shroud until the fan cleared. (sorry for the s***e pics, i didn't review them after taking them until now and it is now dark outside). So now it fits
You need a 1975+ radiator support. The early years have a big fat round back support that will not allow the 2F water pump and fan to clear once you push the radiator back (toward the front bumper_
As you can see in the picture below, you can still use your original radiator support rod. On the other side, the 1975+ supports allow for a second rod on the driver's side.
Last s***ty pic.....on the 1975+ radiator support, you will need to lengthen the holes where it bolts down at the bottom so you can move the radiator toward the front bumper of the vehicle. That way your fan will clear from hitting the radiator itself. Once you install the splash guards, you will also need to cut a small section off it so the drain can pass through it (your choice)....The hardest part will be drilling out the old bolts on the radiator support. After doing that, I had to run down to the hardware store, get me new bots, grind down the heads flat like the originals, and toss them in. I super glued them in place so they could hold temporally as I tightened it all down. Welding it in place would have been best. But 3 years later on hard bumpy trails and nothing has shaken loose. Feel free to ask anything else, good luck.
