Hello folks,
Apologies in advance but I didn't know where this thread should go, so having looked at past topics on fan clutches, a lot of them were from this sub forum.
A bit of background - I live in Europe, where temperatures are typically up to 95F in the summer (it never really goes above this), down to about 25F in the winter months.
It has been quite hot here recently (around 95F or so) and the temperature gauge shows the car is overheating if traffic is slow moving or if it is idling for 10 minutes or more. So I am thinking its time to replace the oil inside my viscous fan clutch.
My clutch is an AISIN 2BK
I plan on taking it apart tomorrow, draining the old oil and filling it with up to 60ml of 7000cst oil.
Questions:
1. My fan clutch is an AISIN 2BK. I cannot find much on it. Is that particular model good or bad?
2. Given the temperature range where I live (25F to 95F), is 7000cst oil adequate?
3. Once I pop the clutch open, should I adjust any of the settings by turning the screws or should I leave it? My understanding is that adjusting the valves inside changes when the fan comes on while changing the fluid adjusts how powerful the clutch is once it is on
4. The thermostat spring is rusty do I clean that with a wire brush or should I use some rust eater paste on it?
Thanks in advance!
Questions:
Thanks in advance!
