I had big plans for becoming a fueling station for everyone. As I struggled with a plan my wife of reason said I thought this aux tank was for you and what was wrong with the way you have done it in the past, I thought you liked things simple. Now if you run out of gas I cant help you and you can blame my wife.
I fab’d this y pipe thing’e to dump fuel into the main tank via the vent line by a transfer pump. Stupid simple and very effective way of transferring
View attachment 943099 View attachment 943100
Mounted an in-line pump for the transfer pump up high and out of the way along with a filter, all outside of the tank.
Time to test….pump runs but I get nothing?? I realize my free pump is a gravity feed pump and will not work. Going with ‘its not the ***-up but the speedy recovery’ I started looking through my junk and come up with 3 Holley Blue pump from my X Trophy truck days. Re fab my mounts and install the Holley blue something I should of done from the beginning anyway being a faster, vane style self priming, and much better pump all around. Now I have transfer and super fast with Holley rated at 110gph.
I will be using a rear window defroster switch Im having relabeled with a reverse negative to give the factory look (not installed yet).
End results
