Do you happen to remember the part number for the Yaris fuel tank gasket? The one I got seems way to big to work.
I used an 83361-20030 and 93319-14010 screws.
What year Tracker and how many gallons? My spare tire space is smaller than stock because of my custom rear bumper so I have to find one with dimension that will maximize the space I have.I used Phil's ideas here for my subtank and Iove the result. I do not have a factory sub tank (4 door Chevy Tracker for $20) but I am using the Holley blue pump and dual filler from @Akella . Vented back to the main tank, repurposed rear defrost switch. I tried to find a factory sub but no luck at the time. Happy with what I have.
Thanks for the ideas and inspiration Phil!
I'm weighing my options and trying to be as frugal as possible. I'll probably end up buying a dual filler neck because I don't have the patience/time to make one as others have. I like the simplicity of a transfer pump.
Looks like I already asked you this question in post #288! haha 99'. Thanks for the second reply to the same question.not sure I ever found out what year it was but a solid guess at a '97.
more info here Builds - Beaten, built, 80 series rebuild thread starting on post #253
I forgot too. Oh well.Looks like I already asked you this question in post #288! haha 99'. Thanks for the second reply to the same question.![]()
Sweet ride! That pipe looks like an accident waiting to happen, though. Very exposed. At least Diesel isn't as flammable as gasoline.Regards from Europe. By checking the equipment spec with VIN number on toyodyi my car didnt have an oem sub tank from factory, then again in the papers I got with the car there are remarks that a 65L aux tank was fitted. There is no aux tank at the moment, but still some remains, with the biggest evidence being the main tank and a fuel tube coming out of it. I never saw a main tank with a pipe like that, which is currently blocked off. Any idea what it was used for?
im in the process of rebuilding the oem sub tank, and gathering parts for my build.
