This thread shows how @LandCruiserPhil pumps the fuel from the sub into the breather hose for the main tank.
DANGER WILL ROBINSON - You are solely responsible for harm you may cause yourself or others following anything below. It started with a $45 factory sub tank. The tank was completely bare with loose baffles inside and everything needed to be fab’d from that point. Testing the tank to make sure...
forum.ih8mud.com
This thread has a picture of the stock fuel pump bracket which has an extra line for the sub tank. It is my understanding that this fuel pump bracket is no longer available. I sourced a used one from Australia when I did my install.
OEM Subtank Retrofit/Install Project With Pics & Part Numbers EDIT>> Sunvisor modifications added 4/7/08, pics and details are at the bottom of this first post #1. There are several dozen posts here related to the 80 Series non-USA factory subtank system. After reading all the posts on...
forum.ih8mud.com
