Bad phrasing, I saw the block in your last picture, just not earlier in the thread.It's right under the arm, behind the latch. There's a 1" gap.
Thanks Ben! Swingdown should make it a lot easier to get the tire on and off since I want to mount it a lot higher.
Yeah like Finny said, I put a block of steel to support the arm. Right now it doesn't budget at all. I don't see the tire moving too much either, aside from the small amount of flex from the bushings. I plan on using some more Destaco latches to hold it to the support. Here's a better pic of the steel that supports the bottom of the arm.
Well this one is a swingout and swingdown setup. It will still swingout to open the tailgate just like any other rear bumper. The swing-down will be attached to the swingout and will only be let down when I need to remove the spare tire.
Thank you sir, appreciate it! But I don't mind feedback, good or bad and I wouldn't call it hatin'. I think a lot is misconstrued over the internet. What may seem like taking crap online would most likely end up being a normal conversation in person.
Just saw your pics, that was a NICE setup. I thought about doing a Poison style stinger but like you mentioned, thought it would get annoying quick. The tubing you see will be on the inside, against the tailgate. It will look like a regular tire carrier, but will disconnect to let it swing down when needed. While I do like the rear stingers, it seems like they stick out further than a regular tire carrier. I'm pretty much going for something like this; swingout, swingdown.
View attachment 1019705 I had to do the same thing, but need to change it to metal like you have as the uhmw is cracking.
Nice, I wanna watch you get that tire on upside down
but really though, just a suggestion - How about using a sandwich style plate with a V-handle on the back? Like how most bedmount spare's are installed. Might ease the pain of bolting and unbolting an upside down tire?
I wouldn't like trying to mount the tire with it being face-down.
I would love to see how one would bolt the tire to a swing down holder when the tire is under the swing![]()
The reason I didn't want a stinger style with the tube outside the tire is because it's not flexible for tire diameter and width if you want to keep the whole thing tight to the body. Because it cradles the tire, you really need to oversize it in case things change in the future. It may also require more tubing which is just unnecessary weight. And, it's harder to get the tire to sit up very high unless you sacrifice lots of room behind the truck.
As for getting the tire on there, not that complicated really. Use a set of ratchet straps around the tire and mount, loosen the lug nuts, drop the swingdown, loosen the ratchet straps, voila. To get the tire back on, just reverse the steps. It's not like if we're changing tires each time we go wheeling so I can live with it the off chance it does happen.
I don't post pics of my welds due to embarassment, so you've got me beat. That looks pretty good... are the welds concave or convex?Hey @nukegoat - see, not all my welds look like herpesI just need to work on being consistent.
You said you have some vibrations right? And what's the latch setup look like?
Ha! That was the next thing I was gonna try and figure out cause no way my short ass would be able to get a 37" tire up that high. I was thinking a simple ratchet strap around the tire just to get it up in the vertical position? I can then attach the lug nuts and torque it down. I already have the tire base with lugs so I'd hate to have to rebuild the whole thing. We'll see...
Its funner and easier to buy parts.....
Found them.
The latch is horizontal and on top, causing much of the potential for vibes, but totally protected from backing up into rocks, etc.
As far as lifting a 37" tire, c'mon, I'm 6' 165-170# and I manage without hernia. But then again I don't sit at a desk 40 hrs/week![]()
Speaking of that, pretty decent welds from a desk jockey!
Here's the stops I built to rest against the gate. Now what everybody is wondering about...VIBRATIONS. Yeah it shakes a bit if I rock the tire back and forth but that's a function of the spindle and bumper shell. The tire carrier is solid; the movement doesn't come from there. Watching the entire swingout I can see the deflection coming from the corner of the bumper shell at the spindle said:
When you welded the spindle into the shell did you punch through the lower side shell also?
I know Luke only puts a hole in the upper shell to drop the spindle into, but with mine I continued that hole downwards through the lower side shell. This allowed me to weld the spindle into a "dual sheer" type situations. Made that back corner solid steel, and gives me almost no vibration at all from this point.
-A
