Electrical Wiring Loom Build
Thanks @nabbasi
As a Mech Eng, I always think of flow going in 1 direction, but I forget, that in the electrical world, power "flow" can be multi-directional depending on which switches / devices are engaged / energized.
I just ignored the ammeter wire circuit as I thought it was only for battery charging, but that is actually feeding the Ignition Switch, when the Alternator is not engaged.
Thanks @nabbasi
I do, too! I think I even suggested earlier making sure you note the direction the current is going, but failed to mention “except for the charging system.” I’m sorry about that..it might have saved you some confusion.
I just had an incident where I had a dead battery in my ‘78. I need to figure out if the battery was just too drained for the charging system to properly re-charge since it’s supposed to only “maintain” or “top off” and not really charge a heavily depleted battery.
Not sure if this is coincidental or not, but I also went with some very, very stout battery cables from @Fourrunner in my ‘67. After using those cables and cleaning up grounds, I don’t have weird grounding issues that I’m experiencing in my ‘67. Just something to keep in mind when you get to harness installation/ testing.
Now that the Beast is gone, I can concentrate on other projects. My FJ40's electrical wiring is an absolute mess and it drives me crazy. Grounding issues, wires sliced / diced, dead wires just hanging around. I am also considering adding an electrical heater & USB ports; so I need some extra power. I know I can buy a harness, but what's the fun in that!!!
I've read several threads and watch several youtube videos on how to do it. So I've chalked up a plan, so I dont screw it up.
  1. Schematic Review
    • Detailed review of the electrical schematic.
    • Identify all switches / devices on the schematic and match them with switches / devices on my FJ40.
    • All wiring to be labelled.
    • Do an electrical calculation to confirm the load / current (fuse rating).
  2. Create Test Bed
    • I want to create a test bed, where I will test each circuit to ensure the wiring is correct.
    • Test bed to mirror the schematic, using small bulbs to represent devices.
    • Generic switches to be used. Some actual FJ40 switches may be used.
  3. Remove Existing Wiring Loom
    • Carefully remove the existing wiring loom.
    • Each wire to be labelled; showing where it was connected.
  4. Install New Wiring Loom
    • Install the new loom.
    • Fingers crossed - hoping I did not screw it up!!
The intent is to post all my work online, so that others may review my work and highlight any issues / mistakes. Also, if anyone wants to build their own loom, they could use my work as a starting point.
This is going to a long / slow project, with Phases 3-4 being in the winter.
which 40 are we working with here ?
1983 FJ45LP-K (QAT)
or
1982 FJ40LV-KC (KSA)
this matters with most of your post #1 # points ...
1983 FJ45LP-K (QAT)
or
I'm working on the 1982 FJ40LV-KC (KSA).
Hey AYM, I'm doing a very similar project, mapping and making a 86' fj45 harness because mine short circuited and melted. What software are you using to map your harness if any?
great!!
Software???? I'm just using auto-cad to draw my schematic. The rest is on excel.
What about you? what software?
great!!
I used canva, its a more simple cad software for ipad, computer etc. It took me a few weeks to finish it but it looks pretty beautiful. Ill attach a photo of it below. Also, the trucks a Venezuelan built CKD, so theres not as many electrical components found in regular late fj40/5s.
WOW!!! That's impressive. The more I look at it the more intrigued. I see you went with an actual approach. Did you pull out your existing harness and then map everything? I like the way its set-up; it shows where everything is located complete with the connector details. Do you have the wire lengths of each segment?
I've taken a slightly different route. I'm actually trying to reproduce the Toyota schematic, based on a GCC / Saudi vehicle. During the winter, I plan to map my existing wiring and then compare it with my schematic. I also plan to make a test board before I pull my existing harness out. Its going to be a long project.
I pulled all of it, labeled what i knew was what and where and for the stuff I had no idea about, I tracked the wires from connector to connector. Basically a big ol puzzle. I did not measure each wire cause it was all melted, but I know my general measurements. I'm figuring it out as I go. All of this is pretty new to me but I'm confident I can do it.
Inspired by @stewt ...I drew my test board.
This is based on the original schematic that I shared earlier. I removed items that do not apply to my vehicle. Most devises are located in the "right" place; of course the wiring route / location is indicative. (Devices shown on the right & lefts sides will not be physically attached to the test board. (I will just add bypass wiring to complete the circuits) I am now in the process of re-checking my wiring schematic against the Toyota schematic. I want to add a new fuse box, that will include for additional circuits for heater / A/C, and other items.
I also want to include the connector details (shown in @stewt 's layout).
I haven't provided an update for a while. Since it was freezing outside, it was a good time to jump back on this project.
I moved into Phase 2 - Test Board. Basically, I am creating a testing board, that would enable me to test the logic of all my circuits.
The switches are all from an FJ40. I have also included other generic switches for misc items. I put test led bulbs in all circuits to check the current flow and now I am in process of wiring it up. Adding wire labels to make sure I am doing this correctly. Battery, alternator, starter motor, & distributor will be separate (on the ground). I find this is a very slow process, as I have check / re-check what I am connecting to what. Later, I am will make another wiring loom, that will have the correct wiring length and connectors.
Unfortunately, I am going to put this on hold again, as I have a more pressing concern on my FJ40.
Wow. Most folks would not go the extra trouble "mach" up the system.
Yeah....i keep reminding myself that I could have taken the easy route and paid $150-300 for a wiring loom. But then again this is the drawback of being an engineer and wanting to do everything "correctly". Its a learning process, and I'm in no rush.
I see the value from a standpoint of building your mental-map of the loom. I don't think I would have gone to that level of trouble, but I get the idea, and by the time you are done you will know every nook and cranny of that loom. I too have a ton of wiring issues in my 78 that was unkindly-treated (at least electrically) and I've entertained the idea of tearing it all out and rebuilding it... But working in sections has panned out thus far.
I think you'll be way ahead by saving the old harness. The deep internals of the harness are usually in good shape, unless something catastrophic happened. Most folks hack the ends of the wiring or bypass stuff. I would guess aftermarket harnesses are probably more difficult to adapt than repairing the old harness.
I think you would be miles ahead by buying like 8 colors (same as my # of fuses) of really good wire with insulation mice don't want to eat and really good connectors. One of those wire label makers would be very handy to mark the ends and maybe along the length every few feet.
