If you had a non-factory steering setup but wanted to use this system, how hard would it be to get a u-joint connection on the end of the shaft instead of the rag joint? Would there be welding involved and would it need to have a bearing installed like the stock column does?
For reference, I'm thinking something like a reversed 525 box mounted like an Astro box.
I am currently in the design srage. Building from scratch. Can you please tell me how you hooked up the left battery and what balancer you used? I am also on a 24v system like yourself. Also i would like to know how many splines are on the shaft and which couplers you needed. Any help would be greatly appreciated. Thanks ever so much.Hi,
I finished installation of the EZ steering kit into my '82 BJ42 24V diesel EUR version about two weeks ago.
After (only a few) kilometers, first impression is very positive. Just returned from a test ride after installing a smaller steering wheel. It's an old MOMO D=36cm, which caused me some difficulties to purchase the right hub.
Especially with the small steering, characteristic of the whole car has changed very much, drives like a go-kart now - at least when I forget about the low HP
Install is easy, Kit is certified by TUEV, which is very important here in Germany if you want your car to be street-legal (nearly everything you bolt into your car needs to be approved and certified).
In case the EPS fails, steering behaves as before install. Electric support is only active and noticeable when force is needed, Steering returns to zero-position like before. Other than for modern cars, support is not speed dependent, but it's adjustable between 'nothing' and 'more than enough'.
So far I can see nearly no negative aspects, only (perhaps) negative point - the maximum power is limited. Enough for street and/or trailer use, even with a small steering wheel, but by far not as powerful as the J4 hydraulic system. It uses a 40Amp fuse, I measured a max draw of 35Amp@12V.
Unfortunately there is no real 24V version available, a 24/12V converter is required, or has to be be connected to left battery plus a balancer (like I did).
Let me know if you have further questions - or wait for crazygeeks report...
Peter
I will give it a road test on the next sunny day.![]()
Waiting for a sunny day here in western Oregon is like playing russian roulette.
Don
Does the Kick back occur under high load ? Maybe a wiring or ground issue. Eventually caused by undervoltage/reset of the ECU ? Remember it's up to 40Amp......Definitely not a one finger assist.
It also had a slight kick back a couple of times. Not sure what that is...![]()
I did not even realize these were available? very cool, curious about the cheapest place to purchase the kit? I looked on eBay and about $2k which you can do a saginaw or mini truck ps conversion at that price. Not sure if this would be an option for me unless the prices come down a bit. I can see it being an option if costs were around $500-$1k......
