EFI Tuning on the Dyno - and 80 discussion
enough baiting on that subject.
No bait, only a lot of lectures today Rick. I'll proceed as tactfully as I can, I got an earful. Wish you were there?
A good day at the dyno today. Amazing to see what a laptop and a well run dyno facility can demonstrate. A shop corner balancing a full race GT3 in the next bay, means you are playing with the pros.
I watched skilled hands fly, typing out modified tuning tables between runs at an average of 1 every 4 minutes. I'm lucky to get 2 in an hour!
I had plenty of time to explore the 80 EFI options with a tuning guru over lunch. As some believe I am here to do business, gonna be a tough report. The first couple reamings I got, I don't even know where to put. It really belongs in the Christo thread from February.
Some basics:
First, to *ANY* MAF upgrade. Quick and ugly. Disconnect the FPR reference line with a larger MAF, expect NOX to go up as a best case scenario. MAF is lean because it's comparative voltage is low, the variable fuel injector differential pressure is adding to/masking the problem. It can "possibly operate a stock truck with crude programming, but don't for a minute under boost or at altitude!" Incredulus that anyone would consider 'Fuel Injector Differential Pressure' insignificant, it's a given constant - he couldn't think of a single exception to stock EFI or standalone. You can choose your constant (3 bar, or set value in an adjustable). Not even with *full* control of every table in an EFI program should this be considered valid. The assumption is that FI Differential Pressure is a constant. Period. He also bet that the stock 80 FPR is a 1:1 rising type, even under boost.
Second, a larger MAF will not have the same output as the stock smaller MAF. I have some graphs that can demonstrate that well. Either the scaling has to be remapped, and or you can hunt and peck injector sizing to hopefully reflect the lower value. "Of course closed loop operation is longer, the larger MAF is always at a lower output value than the stocker. If it's lean during that closed loop, you are better off in open loop sooner"
Dramatic drops in observed AFR's below 12's 9or whereever it takes the dive), means you have no fuel control, period. "Ok, it's saf-er because it's hard blowing up a motor that's rich"
After that bunch of me only presenting 'other's' opinions I moved on to the best 'overall' (not specific product) EFI options for the 80. When I gave him the TCU inputs required for trans ecu, he agreed that the best option is to just pull fuel and timing off the ecu, and leave it in place. We both figured this would benefit the OBDI trucks (finally, an advantage!) because he said many times OBDII doesn't like those controls pulled without DTC's going array.
If the connectors plugs and terminals are available, so is plug and play ability. Ho-hum 10 questions = this is a standard coil/distributor driven 6 cylinder application. Wasted spark or 6 coils are possible.
No real surprises to me at all, and many great stories shared of crazy car projects and nerdy tuning. Good to be involved and a respected opinion in the diagnostics of a low boost problem and dyno table interpretation. Interesting note of the day: The guy uses a knock sensor as a microphone and puts headphones on and listens for knock while he tunes. He claims he always can hear knock this way, way before ECU timing retard intervention.
I'm up to my eyeballs in a plug and play standalone for my turbo quattro right now. But I'm going to do some more research on this project, to see if this is really viable for my 80.
End of Report
Scott J
94 FZJ80 Supercharged
