Hey guys.
I’m attempting to 4 link the rear of my 80.
So far i have a rough idea of what I want to do but you Americans seem to play around with 4 links a lot more than us Australians.
Afaik no one still has really done much on it on the 80. I’ve only ever seen ones with a frames, or still stock length lowers.
So they plan is lower links to be extended around 900-1000mm long, uppers around 70 - 80% of that which puts them around the floor step up for the second row so they can go higher than the chassis rail. Aim for 25% tire size seperation.
I have had a 4 link truss cut and have some universal lower mounts here too.
I want to bring the lower arms onto the inside of the chassis to give them a little triangulation. Ideally having them below the chassis to keep the links flatter but the problem is that it now becomes a huge hang up point closer to the center of the car.
My car is only 1-2” higher than standard so I’m wondering if I’m better off having the arm bracket only just hang below. Like bolt hole sorta inline with the bottom of the chassis?
anyone have any input or ideas?
Also this is Australia so keeping it sorta factory looking with the least amount of chassis butchery would be good lol.
Also the main fuel tank is a issue that no longer exists.
