ibhaters, people bringing random criticism, defending toyota design, blah blah blah
Here's the before. 13 degrees of roll oversteer, low roll center height, tons of flex steer... this is w/ a 5" lift. Horrible. Still flexed ok but didn't work right on-road and was too wobbedy for my tastes. If you're running stock suspension, this is you:
I designed this so the only things that have to be welded on are two frame plates that a lower link crossmember bolts to and a couple of tabs on the axle to bring the axle lower links up (they weld to the oem lower plates for alignment. Oh, and a couple of triangulation gussets here and there for the heck of it.
That said, the truss could be fabbed on the bench, the wishbone could be fabbed on the bench, the links and frame crossmember are fabbed on the bench, and then it just bolts in all win-like.
Sleeve off-road
For you geometry weiners out there
How does it drive? Hopefully good. I don't have exhaust as you can see in the pics so I'll be taking it to a shop to replace the oem water heater with something that doesn't hang below the frame rails.
Sleeve off-road
eagerly awaiting the report on this. I can't remember, did you have a custom 3 link up front ?
