The local salvage yards are asking $150 for any DS. If it is another $150 to get the work done, why is it worth it to have a Frankenstein DS for $300 vs. getting the Slee DC for another $115. I am in Colorado not to far from Slee though. I would think a DS made from scratch would be stronger than a Frankenstein one?... Or is it worth it to save $115?
I spent an hour going through a huge pile of dshafts at a local wrecking yard. after an hour of work i couldn't find a single yota dc joint. tons if spicer dc shafts. so i purchased the slee front shaft and worked it hard 2 weeks ago. but only in the snow. rock testing pending
another thing to consider is the limits of the angles in the dc shafts. after messing with the oe shaft and the slee shaft i can say the d/c slee shaft cant be angled as much as the non d/c oe shaft. but this is no big deal because the d/c shaft points the pinion at the tcase thus "lifting" the pinion and lessening the angle losses of using a dc shaft. I supose the same thing applies to the yota joints. one advantage of the slee joint is that it uses standard 1310 spicer ujoints at the non cv side of the shaft that can be replaced with high angle aftermarket joints.
these angle issues apply to my truck as i now have a 3 link in the front that is very flexy and I have a dana 60 that is low pinion. I have had to limit pass side axle droop due to the limits of the front drive shaft angles. note i have about 6" of lift in the front. perhaps this does not apply to the high pinion 80 series axle. if it did there would probably be reported failures.
also my rear shaft is oe and has 2 angles to deal with as my rear axle is centered. no vibrations even at 70 mph
