Door Opening/B Pillar Differences early to late model?
EWheeler
2 Cruisers, No Garage
Menifee, CA
Visit site
I have an opportunity to get some tub pieces from a member doing an aqualu tub swap. His tub is from an '78 model with flat floor and my tub is a 12/79 with the raised floor for underfloor fuel tank. My passenger b-pillar and door opening lip is hammered from a likely roll-over event that happened sometime in my rigs past life. I understand the inner and outer rocker pieces are different, but could I use the upper B-pillar and door lip from his '78 to repair my rig? Here are some photos of the damage to my passenger b-pillar and door opening. The replacement rockers for the late model rigs don't go up high enough tor replace the damage on the door opening lip.
1MOA
Warrenton VA
Visit site
I would cut that out repair and strengthen behind it and put some 16-14 ga flat steel over it and make your own panel for that area.
EWheeler
Menifee, CA
Visit site
The issue is not the big tear in the metal, its the buggered up door lip and b-pillar. I agree that the flat sheet metal repair is simple.
1MOA
Warrenton VA
Visit site
find someone with a metal brake and a english wheel and make that part too.
It also looks like the door jam area could be cleaned and built back up with a bead weld and ground to match.
EWheeler
Menifee, CA
Visit site
I'm not positive but I believe the lowers are the same. Do you have the later "thicker" doors.
Yes, I have the later doors. I am just curious if there was any change to the door opening shape and B pillar compared to the earlier flat floored tubs. Now that I am thinking this through, his '78 came with the same later style doors as my '79. So, I'm thinking door opening shape should be identical.
EWheeler
Menifee, CA
Visit site
yes, the door jamb area is hammered and needs replaced. That is really the metal that I am after. Easier to just cut out from a good b-pillar and replace my bad metal than have something new made.
SlapSmak
Visit site
That is one from a set I got from them for test fitting. Pretty good quality, striker adjustment holes are a little smaller than oem, but the tail goes down further than oem which looks like what you need.
