I am curious why one would chose a 6 LED bulb style LED over a 20 LED wafer. I mean these 20 LED wafers turn night to day, the installation is simple, are the bulb style LED's superior in some way.
I think we have hijacked this thread pretty badly, hope the OP is cool with it.
basically - yes the hi output ones are *typically* superior to the typical LED.
A nice thing about superbrightleds is they give you info:
4210-CWHP6 Cool White 8~30 165 66 lm 7000K 120
Model - color - voltage range - amps - lumens - color temp - beam pattern.
66 lumens for the 6 hi output w/ 120* beam pattern.
vs another from superbright with your more typical LED bulbs (more like what i think you are showing)
(bottom is regular led - 48 lumen, top is 9 hi output led - 90-120 lumen in comparison) Base doesn't really matter - just to compare.
and it's info:
1156-PCB-W24 Cool White 9~14.8 102 48 8300 15/100
(48 lumens w/ 24 bulbs - 15-100* beam pattern)
I am very cool with the hijack, interesting topic.
I noticed that my luggage compartment light is toast two, both the same way. Looks like heat from the bulb caused the lens to get brittle and fail. I don't suppose that one is the same as anything in the camry. Do the LEDs put out less heat? I thought they did, but I'm not sure.
Peter
Yes - less heat for sure. less draw as well (linked with heat) - nice benefit is if you accidentally leave the dome or cargo light on - you likely won't have a dead battery. bonus. nearly never need to be changed, WAY brighter, etc.
i'd definitely research a good
high output LED. George's task LEDs are nice, but $$ (30'ish last time i bought one). An equivalent (actually superior in brightness) at a fraction of the cost can be found from several online places. I recommend superbrightleds simply because they give you all the dimensions, voltage ranges (think diesel cruisers), lumens (how bright) and beam pattern.
no affiliation - if you find another site that does the same - go for it!
I'm a self proclaimed LED geek - from headlamps, to upgraded bulbs in my cruiser...
HTH - GL!
