I turkey basted about a quart of coolant from radiator first...and I only lost a few drops of coolant from T hoses....with front of LX down on unlevel driveway.
That makes sense, I'll do that. Thanks.
FWIW, i drained 1L from the rad, pulled hoses with T's still attached and lost a couple of cups...That makes sense, I'll do that. Thanks.
So my Ts were leaking, so I swapped them out. No documented history of them being replaced (truck new to me, 2003, 118k miles). The plastic Ts themselves actually seemed to be in decent condition, not too brittle and didn't break as I removed them. But there was old crusty coolant so they had been leaking. Installed new OEM Toyota Ts and fired up the engine to ensure everything was good and ended up with a more active leak than before I started on it. I had put the clamps back where they were when I took them off. I repositioned the one that seemed to be leaking to be a bit further out and it SEEMS to have stopped, but now I'm nervous about it. Should I replace with screw type clamps?
Thank you for the part recommendation LandCruiserPhil. Successful replacement before anything bad happened.Just put an end to heater T's issues for ever.
My heater T broke when I lowered my drivetrain when I was converting my t-case to part-time.
I was happy when I realized I have the correct one time replacement 4Season T's (part #84543) on the shelf. The 4Season T's have 2 - 5/8" and 1 1/2" nipples being SAE and not metric the factory clamps will not seal on used hose so I used the correct sized Breeze clamps.
I did make a tool for removing the broken piece on the fly that worked great.
I have now put an end to heater T's failures forever.
I've searched and have not been able to find the part numbers for the (6) heater t hoses. Does anyone have them handy or should i buy a couple feet of heater hose and cut to fit?
Uncertain there, worked for my '04. McGeorge toyota, where i purchased them from, has a good tool that should answer that.Do you know if those parts will fit any year lc? I have a 2000 and a 2006.
Thanks
