It’s definitely not H41. Different input axle, top cover etc.The third picture I don't recognise but look like an H41 which would fit with a BJ42 and 3B.
Thanks a lot guys giving me good advice,love this forum.That's a 3 speed J30. Throw that shiat in the trash.
Economy and reliability is the main concern for me.What's your goal with the swap? I have a lot of miles behind a 2B and an amc 258 (straight 6 gas). I like the economy and last bit of reliability on my B series when I'm far from home, but the gasser is far more enjoyable to drive imo.
Thanks for reply, I do have a H55 transmission and transfer case from 1PZ diesel engine but I am not sure if it will fit on 3B engine.The L series engine (2.2L) will be too small for the cruiser, they were slow in the hilux that had them fitted.
The gearbox behind the L series looks like an early 5 speed hilux box and transfer.
3B is a better option but still slow, look for a H55 5 speed to go behind it or a later 4 speed.
You'll need the clutch housing for a B engine (B, 3B etc) and the H55F will need a B engine input shaft, which is not easy to find.Thanks for reply, I do have a H55 transmission and transfer case from 1PZ diesel engine but I am not sure if it will fit on 3B engine.
The 1HZ input shaft is not long enough for the B clutch housing. That's why there are separate parts for each application.Thanks guys, the spline on the 1HZ is 21,same my 3B,I am hoping it will fit I will check the part number.
If you have an H41/42 transmission from a BJ4x, BJ6x or BJ7x, and it is the same type (early or late type) as the H55F, yes. But it's a big job to strip the gearbox down that far and you will need a good gear puller.Is it possible to remove input shaft from 4 speed transmission and install to 5 speed transmission.
Thanks, I do see if it is worth it, I do have tools to do the job.If you have an H41/42 transmission from a BJ4x, BJ6x or BJ7x, and it is the same type (early or late type) as the H55F, yes. But it's a big job to strip the gearbox down that far and you will need a good gear puller.
To identify an early or late type from the exterior you can look at the input shaft bearing retainer. The later type has two mouse-like ears towards the top of the retainer face. There are pictures and examples on this site.
So l have a H41 4 speed BJ42 and want to fit a H55 l should look for the same year box to swap over the input shaft?If you have an H41/42 transmission from a BJ4x, BJ6x or BJ7x, and it is the same type (early or late type) as the H55F, yes. But it's a big job to strip the gearbox down that far and you will need a good gear puller.
It doesn't need to be the exact same year, but you'll be looking for a pre 10/85 or earlier gearbox.So l have a H41 4 speed BJ42 and want to fit a H55 l should look for the same year box to swap over the input shaft?
I have been looking for a cheap one to rebuild.
Mine is an 82 so assume that l need an early H55 5 speed.
Why can't l use a later 5speed?
