cheers for the responses, i'd like to get a 1hz with tranny but it would be too expensive for me that way. i can get hold of a 60 series for $1000AUS, this gives me a h55f, transfer, spare engine, power steering, option of wider axles, front disc brakes, and so on. the only thing it doesnt have it the 1hz. it is mentioned earlier in this thread that a 1hz input shaft can only be fitted to h55f's from oct 85' and on.
crushers, from what you're saying, im understanding that if i have a gearbox from after oct 85, it will still bolt up to my 1F (with the right bellhousing) and by changing the input shaft and bellhousing to that of a 1hz, i can also bolt that up? if this is the case, i will only need to track down a bellhousing/clutch etc and input shaft to do the 1hz swap
