Hollywood hills would put me pretty close to Marks offroad for any 40 repairs though![]()
You don't need that for the next 2 years at least, prob. more like 10 years if you treat it with the respect it deserves.
Put the ammeter (amp meter) back in series at the batt + terminal, verify there still is a significant drain (> .5 A), then pull ALL the fuses, under the hood and behind the drivers kick panel. Still no change, start disconnecting things, starting w/things the PO changed, add-ons like stereo, trailer wiring, etc.
Just keep at it until the drain goes away and you know the source.
Or take it to the dealer and pay them $85/hr or so to do it.
The standard approach is as follows. Get an automotive test light. Pull the negative battery cable and put the test light clip on the - terminal of the battery. Then with the probe end, touch a good piece of bare metal. If you have a short, it should light up. At that point, go pull each of the fuses and repeat with the probe. If it still lights, replace the fuse and move on to the next. Once the light doesn't come on, the problem is in the wiring for that fuse. Once you know that, you'll have to start examining the various items on that circuit and find where the problem is.
Destin, I highly doubt you have a draw on such an old rig,there is not much to cause a draw.But if you want to check,grab an ammmeter and set it to miliamps and hook it up in series on the neg side,just disconnect neg bat cable and hook up the ammeter. On this old of a truck,you should have no more than a 10 or 20 miliamp draw and really should have very little. I get les than 50 miliamps on a new porsche with a s***load of electronics to cause a draw.I would guess that your generator just isnt charging enough to hold for 2 weeks,kinda needs to be driven every couple days...Also I have seen where a pos wire can ground just enough to heat up and cause a draw,weird but have seen this happen...
. Your diagram has a alternator but it has a generator regulateri will have to update that diagram...thanks...so would this be closer to destins 64 ...or is the 64 more in line with the 62 that you got?
