I have a battery drain that will not go away. I have pulled every fuse and checked with an amp meter and I still have the drain. I haven't heard of an ignition switch causing a drain on a toyota, but can it be the cause of all my pain? The PO also did a couple of wiring mods that are kind of weird like he bypassed the wiring on the heater fan so it can run with the key off. If it isn't started every day the battery will be dead. I am sick of killing batteries!
