Delta VS Radius Arms (7 Viewers)
Bros, this topic confuses me and I need an assist. How does one determine what radius arms one needs? I bought a pair of Delta 4s after installing a 3” Slinky suspension. I sent Dave at DVS my alignment numbers and he told me go with the Delta 4 arms.
Now I am moving to 37s and want the “long” version. What is the math equation to determine if I need the 3L or 5L?
My caster readings after the lift was -3.9 and -4.4
Have I searched? Yes. Have I read? Yes. Am I mildly to moderately dumb? Yes. Am I ready to be flamed for this question? Bring it on. Just flame me and help me. Thanks. 😘
Have I searched? Yes. Have I read? Yes. Am I mildly to moderately retarded? Yes. Am I ready to be flamed for this question? Bring it on. Just flame me and help me. Thanks. 😘
Hopefully this helps:
I didn't put the 4" or 6" arms because from what i understand they are a previous version and i couldn't dig up what their caster correction was and what (if anything) changed. If someone knows, I can drop it into the spreadsheet pretty easily.
Going to Long arms won't change these numbers. For my lift, I am after the 3L arms to help with my 37's :)
Dear Pell, Get up on those 37’s with your 4” arms and test it out before making a decision. If you do indeed need longer arms always go bigger. 5L. 6+ degrees relaxes the Toyota built in over steer.
Dearest Steve,
I already made the purchase for the Ls but stupidly assumed I needed the 3Ls. Now I am second guessing and trying to determine what I need before Dave ships me my arms.
Pell
You are saying, you want 6+ degrees of caster?!? Are you running the hub disconnects? your front drive shaft is going to hate you!
@FMC80 your 37's are going to rub on the back of your front fender, moving the axle forward is a good way to help mitigate this. So, Long arms or the Redline Axle relocation plates are the way to go.
I ended up with approximately 4.5 inches of lift due to no armor and HD springs. Looks like I should opt for the 5Ls. Although I have armor “in the mail”. I got front and read DVS bumpers coming
Thank you for posting this. I still need to learn the equation. I’ll Google some more
PM your email and I can send you the file with the formulas. It's real easy once you see it
L vs non-L
can anyone use L arms, not just those running 37'? or to put it another way, is there any good reason to NOT get L arms when running 315's or even 285's?
Going to 37’s almost always dictates enough lift that part time is the next move unless you have the skills to run a 3” lift and do a bang up fender modification job.
rubbin’ is racin!
Great chart. This should be on Page 1 o_O
Nice, good to know about the range.
I think you meant “caster”, and yes exactly right. I was trying to say that (regarding the relationship between caster and pinion angle) but stopped halfway 😆
Yu. CASTER. Damned spellchecker Murray been turned off?
Just got back from the alignment shop - here are some real world results on Standard Length 3" Arms.
My setup as measured below:
Icon 3" springs (including their spacer on driver's side F & R)
Delta Radius Arms, 3" Standard Length
Stock Front Bumper
GGM Rear Tire Carrier with a 35" KO2
1/2 Tank Gas
Empty Cargo Area
Current Center of Hub to Fender Measurements
Front Driver: 23.5"
Front Passenger: 23.5"
Rear Driver: 22.625"
Rear Passenger: 23"
Caster Measurements:
Step 0: Before Spring Install (Original OEM Springs):.................................................Driver = 2.3*; Passenger = 2.7*
Step 1: Before Delta Radius Arms (OEM Radius Arms, no Caster Correction): Driver = -2.8*; Passenger = -2.7*
Step 2: After Delta Radius Arms (3" Standard Length):..............................................Driver = 2.5*; Passenger = 2.9*
Total Caster Correction from Delta Arms:....................................................Driver = 5.3*; Passenger = 5.6*
The only thing I did between Step 1 and Step 2 was install the Icon spring spacer on the driver side only, which would change the caster angle just a little bit so I'd lean more on the passenger side correction amount as the accurate number (5.6*).
*Also wanted to add that while it took a while to get these arms, Dave at Delta was very good at responding to my many emails along the way with updates and I appreciate that. The arms are really nice, very high quality.
Stock Front Bumper
1/2 Tank Gas
Empty Cargo Area
Front Driver: 23.5"
Rear Passenger: 23"
The only thing I did between Step 1 and Step 2 was install the Icon spring spacer, which would change the caster angle just a little bit so I'd lean more on the passenger side correction amount as the accurate number (5.6*).
Those spacers look to have taken about a degree off where you should be. The delta arms by the math should be +6.4*
I'm trying to get a lead time estimate on 3L arms so i can put an order in but I can't get any details or response for the last two weeks. Anyone have deets on 3L arms?
Well, I didn't put a spacer on the passenger side, so that's purely correction from the arms without influence from the spacer. I was surprised I wasn't in the mid 3's based off the math.
Funky, how did the bushings on your old arms look that were installed when you took your initial measurement?
I know my bushings look terrible and I am pretty confident that can throw things off a degree either way.
Here are some pics I just took of them.
