Just finished the job myself. My total time spent was probably around 12 hours of which 4 could have probably been avoided if I'd just moved the mid-pipe at the beginning. I spent 9 hours just trying to get the starter loose and out of the truck before I gave in, went and bought some deep sockets (should have already had those and needed for the mid-pipe), and moved the mid-pipe. Once I did that, it took me 3 hours to finish pulling the starter out (2 minutes), installing the new starter, and buttoning things back up.
A couple of things to note that differed slightly from @tbisaacs and could be helpful for future gluttons for punishment. Not sure if the differences were due to my 200 is an LX but doubt it.
- I DID remove the bolt holding the transmission cooler lines in place but DID NOT disconnect the lines themselves so, no coolant loss. Honestly, I'm not sure if removing the bolt holding the bracket in place was even necessary.
- I DID disconnect the solenoid from the starter in my early attempts to remove it prior to the mid-pipe epiphany. However, with the mid-pipe out of the way, I left the solenoid in place and was successful in getting the new one into the right place. I REALLY did not want to try and blindly get the solenoid plunger correctly inserted and the power wire and then the nuts holding the solenoid in place.
- I DID disconnect the O2 sensor wires (which were surprisingly easy) before moving the mid-pipe. I was worried about tearing up the wiring harness. Pulling the mid-pipe out of the way at the beginning would have made other parts of the job easier, like pulling the heat shields and looseing the bolts to the starter.
- I was NOT able to figure out how to use any combination of extensions, universal joints, wobbles, etc. to get to the top bolt of the starter. That was the one thing that almost caused me to give up. However, I'm apparently more stubborn than the 12 year heat locked bolt. The 14mm Gearwrench ratcheting combination wrench finally broke it loose and the after about 200 cycles of 1/8 turns the bolt finally came loose from the starter. The bolt does NOT need to come out of the block completely so leave it there to make it easier to put back in.
- The clip for the trigger wire broke on mine as well. Following one of the Tundra YouTube videos, I ran a dab of Right Stuff across the two halves of the connector and hopefully, that set up into a solid'ish silicone strip that will serve to keep the pieces together.
Knowing what I know now, I could do the job significantly quicker but there is just no way to speed up certain things like getting the top bolt out. If I have to do it again, I'll probably pay someone else. However, I'm assuming that I'll be driving an electric Tacoma before this one would need another starter so I'm not TOO worried about it.
Thanks to @tbisaacs for the thread and useful info. I don't think I would have pulled the mid-pipe if he hadn't done it.
