Gotcha, a HP 9.5" diff. Very sweet. Have any pictures of a setup like that?
This is the small front diff from my cruiser ute , when it was on 31s
all that shine near the red paint is missing teeth
That would be the non-elocked version by the aussie locker, so from a 91-92?
I remember a local Mini guy saying he installed a thrust block on his HP 8". A machined block that is a mm or so away from the ring gear, opposite of the pinion, which all but eliminates deflection. Deflection is what causes the ring gear to shave off teeth. Says he hasn't blown a diff since, and has installed a small block.
Example: True Hi9 high pinion Ford 9 inch third members richmond
You musta been wheeling it pretty hard. I got some auto-lockers with my 80 and ended up selling them instead of putting them in. Looking at your pics I think that may have been a good idea. I suspect I might have an easier time getting into trouble on 37's and the cummins, then I would on 31's witha 3FE..![]()
coulda been bad heat tempering or porosity in the steel of the ring gear??
Im curious now about how much stronger the e-locked version is versus the non e-elocked. And what it is that makes a difference between the two.
I think if I have the diffs apart again, I will look into how hard it would be to add a "thrust block" in. But then I may just be transferring the "weak link" to somewhere else...
Interesting, the "change in spline count" IS making a 1.5" 35 spline axle shaft fit in a cruiser carrier. And it has already been done.
D60 rears are only 30 spline BTW. D70 rears are 35 spline (and D60 HD theoretically/sometimes apparently)
