Cruiser Patch 100 Series Products Thread
2x engine mount kits in stock now
3x transmission mount kits in stock now
Just replaced mine and found out why the engine had been vibrating so much- oops (1999 LX470 w/ 295,000 miles)
I've seen the transmission mounts fail on 80 series before leading to a radiator puncture from the fan blades- not an easy trail fix.
Giving away a FREE center console cover lid via a sweepstakes (recovered with Lseat leather in Ivory/Tan/Bisque). Enter to win with orders over $100 using code "100CONSOLE" and add an 8x3 Cruiser Patch sticker to your cart.
This functions as a lottery- there's an equal chance to win for every customer who orders $100 or more from CruiserPatch.com between 5/20 and 5/24 (8:30PM EDT). Additional orders will NOT be counted twice (only one entry per customer)
Don't forget the sticker! Cruiser Patch sticker - https://www.cruiserpatch.com/products/cruiser-patch-sticker
Here's a good product candidate for the $100 entry: 'Cruiser Patch' branded YotaMD YMD1 titanium reinforced key kit - https://m2vovbz4ymc3o2rl-78579073338.shopifypreview.com/products/cruiser-patch-branded-yotamd-ymd1-titanium-reinforced-key-kit
Giving away a FREE center console cover lid (recovered with Lseat leather in Ivory/Tan/Bisque) with all orders over $100 who use code "100CONSOLE" and add an 8x3 Cruiser Patch sticker to their cart.
I think there's some kind of glitch; it won't let me enter any address for shipping that doesn't say "Shipping not available."
Or is it me? :rofl:
Or is it me? :rofl:
Hey! Send me a DM or email and I'll help you get it sorted. Apologies for the inconvenience-
So how many of these you got? Im assuming you can support several customer orders? Or is it only 1 available?
Only one available- it's a sweepstakes for one of them. Apologies, should have made that more clear
After re-reading the original post that was extremely unclear. I've edited the post to better reflect the intent of the giveaway.
So is it first come first serve or a lottery?
Lottery- equal chance for every customer who orders $100 or more from CruiserPatch.com between 5/20 and 5/24. Additional orders will NOT be counted twice (only one entry per customer)
View attachment 3636636View attachment 3636637
You take better pictures of my product than I do. Nice work!
I'll share some of them if you want! Thanks again for collaborating!
Installed mine yesterday :cheers:
100 Series 2UZ-FE Heater Tee Hose Kit​
Back in stock- I have 5x OEM heater tee & hose kits and 5x metal heater tee & hose kits
CruiserPatch.com
I exclusively use constant tension clamps when replacing heater hoses (or any kind of OEM hose for that matter).
Occasionally after replacing the heater tees one can cause a leak- replacing old hoses is a great next step.
100 Series Front Diff bushing installation tool​
Thanks to @MongooseGA for the original concept. I've got one with your name on it.
These are now available on the website-
The quick and dirty:
  • 304 tumbled stainless (.250" thick.)
  • filleted corners and edges to protect OEM rubber
  • central hole for threaded rod/DIY press installation
  • made in USA
Hi everyone, hope you guys are doing well. I have a 1999 LC100 1HD FTE. The diesel (injector) pumps connectors wiring coming from the ECU was cut off buy some "famous guy" and now I'm sitting with the mess of not knowing which wire to connect where on the diesel pump connectors. I Am in desperate need of someone to assist me with some pictures of wiring coming from the ECU side to the pumps connectors. (The coloring) the help will be much appreciated...
We should probably move this to be a proper thread, higher chance you'll get responses than buried here in an unrelated thread.
When are the transmission cooler lines kits coming back in stock?
Do you think installing the AHC shock extensions in the front could potentially give me an extra 3/4 of an inch droop? I’m thinking about doing some kind of space or something just to get a little bit extra droop. I’m not using a sensor lift. Trying to find something like that, and came across your stuff. Thx
