cruiserpatch
Supporting Vendor
- Joined
- Nov 24, 2020
- Threads
- 140
- Messages
- 1,419
- Location
- Atlanta, Georgia
- Website
- www.cruiserpatch.com
- Thread starter
- #121
You'll need to do a fair amount of trial and error/research to figure out how they will work with your shocks and how much you'll need to drop the front bump stops (to prevent blowing up the shocks).Do you think installing the AHC shock extensions in the front could potentially give me an extra 3/4 of an inch droop? I’m thinking about doing some kind of space or something just to get a little bit extra droop. I’m not using a sensor lift. Trying to find something like that, and came across your stuff. Thx
I actually removed mine up front and only run them in the rear. Most setups will require a limiting strap so you don't bind the CV axles or UBJs. Eventually I'll buy a shock with the correct stroke like Icons or Kings instead of fooling with spacers up front. The juice ain't worth the squeeze for my setup but may be for others. They work phenomenally with AHC since the rams do not top out like conventional shocks would.
