Hi all well this is my fist post here, but I have been lurking and have picked up some great advice over the last year. Iv searched but have found no info on this, I apologize if its been covered.
I have 80seires I picked up last year. Iv have slowly been fixing it up as and when I can afford to.
Today I decided to do all the oil. Engine, Gearbox, Transfer case and Diffs together. All went smooth until I got to the Gearbox Drain plug (there is silicon around it) So I thought thats weird. pulled it off, cleaned it up, re installed. Filled up the gearbox... and in my final check see its seeping oil at the gear box drain plug. So I drained the oil (again) wiped the area clean and got the torch in there...and that when i just about threw up. Its Cracked! through the threads. I know its a tapered plug and previous owner or whoever did it last must have overtighned it and cracked it. (explains the Silicon)
So my question is what do I do now?
I dont have pics but the if you can envision it, the crack runs about 1/2" on the inside of the threads in the case and about 5/16ths" on the outside.
All i had on had was Thread tape and Gasket goo. So I taped the threads and applied gasket goo to the washer. It has not leaked since driving home. (50klms)
Anyone had this problem, what are the possible solutions?
Just leave as is and keep and eye on it?
is there a better recommended "FIX" ?
Its and alloy case, Can that be welded?
Any advise would be greatly appreciated.
Cheers Andy
just when you think your getting on top of things
Cheers Andy
