1994 transfer case fill plug and drain plug
Usa
Hi
I searched the forum and found some conflicting information. My transfer case fill plug is stripped so I need to buy a new one. Does anyone know the part numbers? I have 90341-18039 for the fill plug? is this correct or is there an alternate part number? Does anyone have the drain plug part number? Toyota told me this morning that they do not have this part any more?
thank you
Your number appears to be for a plug for a check ball, not a drain or fill.
These are what I could find, and I just replaced them as well.
Fill: 9034118006
Drain: 9034118057
2 X 9043018008 gasket
New
Fill: 9034118006
Drain: 9034118057
New
great thank you
Transfer case drain plug is 90341-18057 with gasket 90430-18008.
Transfer case fill plug is 90341-18006 with gasket 90430-18008.
Both are available at any Toyota dealer or online. These are also used on the front and rear differentials. You can also use the Allen key drain and fill plugs 90341-18021 for all 3 drain and fill. However the axle housings use a different gasket 12157-10010.
Or upgrade
thank you!
