Cowl Vent Screen
Durham, NC
Help me brainstorm a solution to our common blight of leaves/pine needles/trash falling into the cowl and being a total PITA to clean out.
The Problem:
There are a ton of threads about people dealing with rust/rot in the cowl area around hte HVAC intake due to trash getting in the cowl:
The Solution:
Many old cars have cowls like ours, but they have screens in place to keep the larger debris out. If we're able to keep the larger debris out, then the factory drains can work more effectively for the rest, and prevent buildup of junk both in our cowls and in our HVAC blower motors. The question is, how do we do it? This is the part I need help figuring out, how to install a cowl vent screen
Our cowls are spot-welded in place, and the cowl vents are part of that panel, so accessibility is an issue. The vents themselves are formed similar to louvers, meaning they're not just holes, but protrude downward into the cowl, meaning adhering a screen to the back with VHB tape or similar is difficult. Furthermore, the windshield wiper squirters come through one of the vent holes, so any screen would have to have a hole to accomodate them.
This is not an issue unique to land cruisers, but what's the best solution for us? Screen on top of the cowl? Something welded to the backside?
I'm open to suggestions.
This is the goal, although this specific solution is a little redneck for me :lol:
@cruisermatt help figure this out
hmmm. I think I have an idea. Need to look at a 60 to determine feasibility.
As a counterpoint- if the cruiser isn't permanently parked under trees that shed, the area under the cowl vents never gets debris in it.
My 30 year old cruiser never was parked in a garage (or stored under pine trees) and the cowl pocket under the cowel vents had zero debris in it (after 30 years). It was clean as a whistle.
I think the cowel vents on the hood need to be open without a shield to allow an air ram effect from the windshield when driving, pushing air through the vents.
The old Subarus (1990s) had cowl vents like the cruiser but there was a metal mesh installed beneath them - about 3/16" to 1/4" mesh
I feel like that's obvious, but thanks for the point.
There is no "ram effect" at the base of the windshield. The base of the windshield is a negative pressure area.
Maybe a cowl vent scoop over the cowl vents? Could drill a hole for the windshield squirters or something.
I have been trying to think of a solution as well! My idea was to try and cut stainless screens with magnets and slip them through the access ports and stick them up under the factory slots.
I remember reading a post a while back where a k&n air filter screen was used and looked as if it fit pretty well to keep out the debris. Do not remember post title or who it was. I think I took a picture of it though. HTH
That seems like it would almost create a venturi...air going the wrong way.
The panel inside my cowl is in great shape but that intake screen in behind where the wiper motor mounts is rusting where it's welded to the panel. I have no idea how I'm going to get in there to treat it other than just spraying a bunch of Fluid Film on it. Which will stink up the intake like sheep.
This screen: (not my photo)
img_20130917_162129_400-jpg.807526
I tried that. I couldn’t get it over the screen well and it was a MAJOR pain to try and fiddle it on. Definitely not something I would want to regularly do since you have to take the wiper motor and linkage out to get it on and off.
Yup, that's a thing for sure, but what I'm suggesting is a screen to prevent leaves/pine needles from getting in the cowl in the first place.
At speed it's a low pressure area, doesn't really make a difference. The blower sucks air in.
I believe most windshields generate a vortex near the windshield; lots of hood scoops open to the rear for that reason. I think the rear-opening cover shown here could work great.
Maybe cut out the louvers and 3D print something to attach using nutserts? With a good paint match you’d barely notice it.
Don't even need to cut the louvers out, just attach something to the cowl. Nutserts, VHB tape, whichever.
Perhaps the fix for the windshield squirters is to move them to the hood? That wouldn't be hard with something like this:
Amazon product ASIN B077D1MXSB
My though for cutting out the louvers was easier access for cleaning. I’ve never tried to get in there before but it seems like access would be a good thing.
Living in an evergreen rainforest I just assume we’ll have piles of needles everywhere at all times.
Screen will work fine, just need to make a nice contour for looks. I build screen for are sleds like this would work. I rivet them but you could double face tape them, lot of possibilities. I make these out of plastic.
Sorry for the sled pics..:grinpimp:
To clean, you don't need access in the center, you need access at the ends. There are holes in the firewall for this, but on the PS you need to remove the wiper motor, and if the drains are clogged, you need to remove the fenders to gain access. Not a huge deal, but im talking about preventing the need to clean. See here.
Geez Johnny looks like you drove through a riot
The Problem:
The Solution:
This idea seems the most feasible, try SS mesh with plastic magnet glued to it. Something like a door sign magnet
surrounding the mesh so it can be removed easy enough. FWIW, I'd personally use electrical tape, no residue and from
past experience lasts a really long time. I've used it for many leak proofing applications from sunroofs to windshields
You know, I hadn't thought of a magnet. That might be the ticket, some window screen material and a magnet or two to hold it in.
