Doesn’t look too badI slid sideways off the wet rocks and into a broken tree branch on Tin Cup Pass. That's one step closer to a full Raptor job.
Couple years back I got impatient getting past an obstacle and ended up getting too cozy with a tree and ripped the tupperware from the rear pax door. Luckily no sheet metal damage.I slid sideways off the wet rocks and into a broken tree branch on Tin Cup Pass. That's one step closer to a full Raptor job.
I really like the look of the flares, so I intend to keep them. I'm surprised at how tough they are.Couple years back I got impatient getting past an obstacle and ended up getting too cozy with a tree and ripped the tupperware from the rear pax door. Luckily no sheet metal damage.
So I understand the feeling
I still go back and forth on taking all the cladding off and just raptor lining the lower part of the body
I dont dislike how they look. But the clear coat on mine is pretty bad and so are the gaskets. But cosmetic exterior stuff is very low on my to do list. So for now, Ill keep it as it isI really like the look of the flares, so I intend to keep them. I'm surprised at how tough they are.
Ok, now we've passed "weird" and have entered "creepy".Keeping up with that twin theme
Once again I got cozy with a treeOk, now we've passed "weird" and have entered "creepy".
What happened?
Definitely need a steel bumper. I can't imagine there'd be much left of a factory bumper on mine with the shots I've taken.Once again I got cozy with a tree
Got into a bad spot and it was either that or the side mirror.
Im about to order new bumpers, so it is all good!
Yeah, that, and I finally own a spare tire and I need a place to put itDefinitely need a steel bumper. I can't imagine there'd be much left of a factory bumper on mine with the shots I've taken.
I had similar problems this summer with my dc-dc charger. The diagnostics indicated it might be the alternator, but it ended up being a dodgy mega fuse the finally failed.My truck came with a dual battery system inc. a BlueSea isolator and a switch. There's a Slee dual battery monitor on the dash, which has behaved erratically since purchase. On long days, it puts on a Pink Floyd light show for me. I did a bunch of (flawed) testing, replaced the switch (it broke) and the isolator (recommended by PO), and had concluded, for a minute, that the Slee LEDs were malfunctioning, but just as I started accumulating parts to remove it, I did one more test and determined that I was losing a volt between the battery and the isolator. I traced down that cable and wondered if there could be something wrong with the Megafuse on that line. It does have some corrosion and one of the nuts didn't feel as tight as it should have been, so I replaced it.
I uprated it to ensure it could carry full alternator voltage at 200*F. I slathered all the mating surfaces with conductive grease. So far, it appears to have worked - Pink Floyd packed up their kit and headed back to the UK. I'll know for sure on the next long trail ride.
Side note: I'm really disappointed in BlueSea's customer service. They were responsive in the past, but its been a whole month and they still haven't responded to any of the three messages I sent them in trying to troubleshoot this system.
