Coolant Leak
hatfieldcb
Colorado
Now I've got a coolant leak somewhere and I can't find it. I replaced my PHH yesterday. I looked all around in that area and don't see any evidence. It's a pretty steady drip, drip, drip and it's coming off the tranny pan. It's red and I'm sure it's coolant. I used the red lined silicone heater hose, but not constant tension clamps for my PHH replacement. I suppose it's possible it's a "cold" leak at the block. Maybe if I tighten the clamps a little more? What else could it be? Could I have cracked a rear heater hose when I back flushed the system? I just can't see where it's coming from. If it is the rear heater hoses, how do you get to them, from inside the vehicle? Any help would be appreciated.
Shufflin' Through the Texas Sand
Chris...get up on something end get over on top of the back of the engine with a light. If you are 100% sure its not the PHH, my guess is its one of those rear heater hoses that's seeping and you can't see it.
hatfieldcb
Colorado
Thanks guys. I've looked and looked. I'll look some more. Could it possibly be a cold leak at the block side that's traveling? There is a ridge just below the PHH. I suppose if the clamp's not tight enough it could be that. I'll keep looking. :rolleyes:
e9999
You want to do what...?
Moderator
US
you could put in some fluorescent dye but that seems overkill. Surely you shoudl be able to see it.
If you like to live dangerously, warm up the engine and see if it sprays some place...
hatfieldcb
Colorado
Hi Eric,
I did that. No spray. If anything, the leak subsided. I shut it off 20-30 minutes ago and, for now, it appears to not be leaking. :confused:
e9999
Moderator
US
what did you do to this truck? now that it can't do the PHH on you any more for a while, it's working on another hose to blow up any time... Just to keep you interested...? Must be a female... :D
hatfieldcb
Colorado
No doubt! Just drove 60 miles R/T. Stopped for 20-30 minutes in between. Nothing. The pavement was dry underneath the vehicle. I'll see what happens over night after it sits. :confused:
hatfieldcb
Colorado
OK. Now it's sat for a while and I've got a small puddle underneath the PS firewall area. Must be a lower heater hose. :mad:
e9999
Moderator
US
so, it's a female and it's piddling in your driveway...? :eek:
alia176
Tijeras, NM
Considering that the oem clamps were not nearly as high tech or strong, I think you're fine in this dept! :D
hatfieldcb
Colorado
Well I just had it pressure tested and no leaks. I guess I'll just have to keep an eye on it and have some faith. ;p
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
Chris. That puddle you got after driving is normal if its clear. It's from the AC. If its Red it is not.
Not use to AC with the pig.
e9999
Moderator
US
Oh no! was he talking about the A/C condensation drip???
that would be funny.
But he did say it's red though...
hatfieldcb
Colorado
It was red the other day. Not sure what it was last night, but it was gone by morning. I'm just going to keep an eye one it for now. :)
Romer
Moderator
After driving with the AC on there will be a drip for a while were you described it. If it was on the garage floor, there would be a red stain. Otherwise, normal operation. Could the other have been spilled coolent that collected somewhere and driped down later?
hatfieldcb
Colorado
Quite possibly. It was dripping down off the tranny pan. I suppose it could have collected somewhere. I'll keep you all posted. ;)
hatfieldcb
Colorado
My leak showed up again. Definitely red coolant. I took a look tonight and my PHH fix is leaking!! I tightened the hose clamps. We'll see. :eek:
