You want to set tdc when the pistion is coming up, ie: compression, correct?
Noah
Correct. You can also watch your rockers on cyl #1 to confirm it's on the compression stroke.
The BB is close enough to the TDC mark for what you're doing now.
Noah
ok, have been doing some reading and using the search button
question: I have been using the bb lined up with the pointer, I read that I should be using the "tdc line" on the flywheel, is this correct?
question: when determining tdc, someone mentioned that a good way to do it, is to watch the #1 piston and put your thumb on the hole and you should get pressure on the #1 pistion. You want to set tdc when the pistion is coming up, ie: compression, correct?
Noah
definetly check your valves first.......
So, you adjusted the valves correctly, and now it runs.
any input on where I should be looking on the valves for oil coming through?
thx guys, got the eninge to idle ok yesterday evening. Hoping to get some clutch and brake pedal today and I can take it for a spin!! I told my 3 year old daughter she gets the first ride.
the PO has a mechanical oil guage in there. Have never dealt with mechanical guages before. Seems there is a tube hooked to the oil cooler, then a power and a ground. Is that correct? I plan to check power and ensure ground and see if I can get it working today. I am still nervous about the oil pressure thing. I am concerned I have not bottomed out the disty but it seems to be in there just fine. If I can't get the guage to work I may just go buy a cheap temporary oil press guage at the parts store and pop in in the engine compartment just so I am sure I am getting pressure.
Noah
Power and ground should be for the light.
The pressure works directly on the needle.
If the setup had not run for 10 years, then the oil pressure line may be dry/blocked, kinked, or just need to be bled out, like brakes. Disconnect from back of gauge and start engine. Let it run for a minute or two and see if oil comes out. Keeping the engine running may be either or both the choke setting at the top butterfy, and/or the idle mix screw. That usually ends up around 2-3 turns out from fully closed. DO NOT force the idle screw in. It should turn with some resistance, but you should feel it when it hits bottom. I'm gussing that your fuel level in the sight glass is staying up OK when you fire it up. JohnMy mechanical oilpressure gauge jumps up pretty quickly on start-up...much faster than the stock electrical.
Edit: But it's all primed...
I just decided to pull it apart, should have the parts tomm morning.....
